- Mar 11, 2001
- Auburn California
What are your temps with prime 28.5 small ffts at 1.325v and 4.8. If they are under 90 that is unusually good.
have to test, ive been using blend
29C idle 87C small
on another note....5 ghz prime (does 10 mins count )
I'm gonna try the ice bucket, but won't go higher on the vcore.Temp are great, but 1.48vcore?
I'd be more worried of that chip having a very short lifespan.
Highest I've gotten with mine is 5.1ghz @ 1.48vcore. Not sure how much higher I want to go. Cooling with tap water but I'm going to switch to an ice bucket. After that, I might try delidding.
if i try the ice bucket again i think i will add some salt to get the temps even lower and insulate the water block. i had some moisture forming because i had a fan blowing on the VRM heatsinks.
delidding and lapping changed little. have to bleed out air bubbles and check again, but still 99C with 1.325v
Ya it's a pretty bad generalization, but regulating tens of amps on dye means you get a fair amount of heat from the small drop, and I bet the thermal diode is right next to that.I doubt it's a problem with haswell... Wouldn't all of them have that problem? Pretty blanket statement there.
