It is the same chip, just binned a bit higher, with better TIM, some added caps, and some software bumps (Vt-d is the only one that may be useful). Whoever said IPC was increased, was smoking the good stuff. There wasn't a piece of literature that mentioned IPC increases.
Thanks ED, that's what I thought. Always good to be confirmed by you.
I thinking I can just delid and get a chip of similar quality. So far, from many forums that I read, I do not see the 4790k getting any higher overclocking speeds.
which is a pity.. if 70% can get a stable 4.8Ghz under 1.4V on it, I will go for it.
