- Apr 16, 2001
So after what I thought would be a mild GPU upgrade to the RX 570, my EVGA 430W PSU just cannot supply the power the RX 570 needs. I currently have an old Antec 500w Earthwatts in there for now. But it only has one 8-pin connector. Which I plug into the motherboard. So I plugged a 6-pin into the GPU. I do have a 1300w PSU but it is loud as heck and of very questionable quality. I run 100% fine with the 1300w PSU and have a few issues with the 500w PSU. And after shelling out the money for the GPU I was hoping to not need a PSU so soon.
I was thinking of this SeaSonic. It is a very old tried and true PSU. It's also cheap. I know from my research it doesn't have all the protections some of the newer PSUs have. So I am in between a rock and a hard place. Is there a comparable PSU out there in the 600w range that is similarly priced? I've looked quite a bit and have been out of the hardware game for a while so I am not sure who is rebadging what anymore. For me reliability is first, quietness is second, cabling and such are a distant third and beyond.
System Specs:
1700 Ryzen (stock but can overclock a bit)
Stock Cooling w/RGB
Gigabyte B450 Aorus Pro WiFi
16Gb RAM
MSI RX570 8Gb
500Gb SSD
1Tb 7200rpm SATA HDD
DVD-RW Drive
3x 120mm RGB Fans
And a bunch of USB Devices plugged in.
System Specs:
Stock Cooling w/RGB
16Gb RAM
MSI RX570 8Gb
500Gb SSD
DVD-RW Drive
3x 120mm RGB Fans
