- May 15, 2010
- Euroland, Denmark
Hey guys.
I just ripped apart my main rig, for a rebuild, the loop as around 10 months old, but the fittings may have been around 18months.
All the fittings are EK nickle plated, push over type, where you clamp the hose.
I have found serveral fittings now, with a gree/white build up on it, the same build up, is found on my silver coils, with one silver coil even showing rust!
The loop has always been destilled water with kill-coils. The types are nice and clean on the inside, i cut one up. But i am worried about the rest.
Is there a way to avoid this? Why is it happening, the loop isnt THAT old, and i have replaced GPU's a few times over the last 10mins, so fluid has been replaced too.
