Alright, ive had these pop up from time to time and my last one was kinda crappy too. It involved mineral oil as an insulator to fight condensation for extreme cooling. Basically a shallow tank that submerged your mobo to keep water droplets from forming on components.
But ANYWAY, the next one...
We know that pressure affects our temperature, Low pressures are usually warmer, high pressures are usually colder. With our radiators its generally the same, by that i mean, if your rad is warm, the air between the fins is less dense. So the reason i am bringing this up and im curious about it is, 1) I dont have a 120mm rad to test with, and more importantly 2) if we turned our static pressure fans to both push air into the radiator directed at each other effectively forcing a higher pressure in the fins of the radiator, Would it effect our temps? same goes for the opposite orientation, both of them blowing out, causing a low pressure(though i think this would raise temps).
yes it sounds crazy and would probably be worthless to even try but if anybody wants to give it a go let me know how it turns out.
