- Apr 26, 2012
- New York, USA
Well in this case volatile is kind of a misnomer. Volatile not like gasoline but as in boils at low temp. I wont disagree with you, but it would seem that they dont use the more volatile liquids because they would evaporate at a higher rate and leave air in the system. A completely sealed loop would prevent any loss in this way. Once again id have to check with the physics professors, but I think if it boils at room temp, it would transfer heat better than water. The use of water very likely has something to do with availability and not needing special certifications to handle it as well as how reactive it is with the tubing. Im thinking isopropyl though. Iso would take in the heat and give it back faster.
Now its time for me to bow out though, because Im an air cooler after all.
Edit: I seem to remember reading that copper heat pipes on air cooling rigs were sometimes filled with inert gasses. Im just thinking of an expansion of this concept and having the gas move through the radiator.... Im ceertain there are thermal issues to be overcome, but the base concept is (IMO) solid. I do see the problems that could arise though. I really think cost would be the biggest issue though. Each system would have to be custom built, or there would have to be a wide array available for popular case designs.
I understood that you didn't mean volatile as in explosive, but think of this: When a liquid reaches the boiling point, the molecules in the liquid are moving extremely fast, bumping into each other and the surfaces of what contains them. Now think of a pot full of boiling water, the bubbles that are moving from the surface of the pot to the air are not full of air, but rather water vapor. They do this because the water vapor is less dense than the liquid water. Now, if you put a tight-sealing lid on that same pot, what happens? Momentarily, the water stops boiling. Why? Because the water vapor quickly equalizes the pressure above the liquid water. But then what happens? If left long enough, the pressure will build to the point of "boiling over", meaning that the pressure inside the pot will exceed the seals ability to hold.
Now, if you were ever young, you may have at some point taken the cap off of the radiator in your car after driving it for a few minutes. If you did, you may have found that the liquid inside the radiator boiled out of it. This is for the same reason as the pot in the paragraph above, but what makes it different? The radiator cap. It's designed specifically to maintain a low positive pressure (somewhere between 9 and 15psi, generally), and if the pressure becomes greater than that, the fluid is blown off into the reservoir. Why don't they just allow the pressure to continue to build in the radiator? Because, as it is with computer water cooling loops, there are seals within all of the parts being cooled, that will fail at various pressures. Even if they don't fail immediately, the higher the pressure in that loop, the better the chance for an explosion once something does fail.
Now back to the more volatile liquids, the molecules in them move faster than that of water at the same temperature. This means that at any given temperature, the pressure in a closed loop will be greater for those liquids than water, thus increasing the risk of failure to the components of that loop, and the possibility of an explosion.
As far as the inert gasses, yes, a lot of them are. But you have to figure, these heatpipes are solid, with no seals and no moving parts. They're designed to handle much more pressure than the gas can produce at the temperatures of current computer equipment.
