Hi there,
I signed up here because you people seem more fit to help me with my problem then the guys over at the other forum who tell me not to OC my CPU while browsing a forum about overclocking....
So here's my problem:
I tried to OC my FX 4100, but to be quite fair, I'm a total noob at this and kinda chicken out when my system starts herpaderping.
Anyways, I tried an OC of 4.0 and it's running more or less stable. I've had one BSOD after which I upped the voltage from 1.4125 to 1.4250. I haven't done any real stress testing. I've tried Prime95, but that program is kind of complicated + it totally failed at a 1 minute custom test. I did however do a lot of IntelBurnTests. I tried a couple of runs on Very High settings and my systems passes them perfectly. Did another one of about half an hour and this one also passed without fail.
So I kind of need a guiding hand to fine tune my system, with minimal (preferably no) risk of blowing it up.
Another problem I seem to be having is that my CPU throttles back to 3.3 gHz within 1 minute of stress testing. The only way to solve this problem is to enable and disable turbo boost in AMD Overdrive each time I turn on my computer, which annoys the crap out of me so I'm looking for a more permanent solution.
My system specs are made up of:
CASE: NZXT Phantom
MOBO: AsRock 970 Extreme4
CPU: AMD FX 4100
CPU COOLER: Mugen Scythe (heatsink + 2 fans, one sucking air, the other exhausting)
RAM: 16 GB DDR3 1.333 mHz (or at least it should be)
GPU: Ati Radeon HD 6850
PSU: Corsair TX650
2 hard discs: 1 SSD for my OS and programs and 1 HDD for games, downloads, backup, ...
I also have a total of 5 case fans: 2 large ones, 3 small ones (no medium sized fans). the 2 large ones are at the top with 1 sucking in air, the other exhausting air. I also used to have a large one at the side, but had to remove that to clear space for the CPU cooler...
I believe that's all the relevant information.
(My apologies if the next part bugs you out, but I don't seem to be finding the spoiler tags)
I also have a couple of CPU-Z screens:
And this is a screencap from the Hardware Info program, however, temperatures aren't accurate as I only just ran a quick stress tests to get the voltages as I can assure you that the system gets cooled adequately (CPU cores stabilize around 36.5-37°C and the overall CPU stabilizes around 46°C as seen after a 30 minute stress test)
I really hope you guys can help me with this. I've been reading a lot about it on the internet, but I'm still touching around in the dark and of course there is the chickening out...
So please save this soul from damnation and my CPU from me (aka going BOOM!)
PS: if I don't answer in a while that's because it's 3:45 am and I'm actually going to bed.
CASE: NZXT Phantom
CPU: AMD FX 4100
PSU: Corsair TX650
