- Jun 12, 2003
- Houston, TX
wow, anytihng above 2.0 v just scares me... I got mine up at 2400, but not stable.. it's a 1.6v 1700, not a 1.5
Southpaw said:I must be doing something wrong....
I can only get my DLT3C up to 1909Mhz...
I will have to verify the entire stepping and get some "help"
SP
emericanchaos said:
DUT's are hard to get over 2.2Ghz. DLT's do that easy. DLT's don't like the high voltage all that much though so becareful with that.
Tyranos said:It has the brown wafer if thats what you mean. Package wise, it was an oem, so that would be clear.
Running at 2525mhz at 1.94v super stable. I want to try for 2.6 soon. Idle temps can be from 32c to 40c depending on ambient and load is usually 39 to 46c.
Tyranos said:2620mhz posts but freezes loading windows. Thats at 2 volts! I am upgrading to watercooling soon, so maybe that will yield better results than the slk800u + tornado.
RedDawg41 said:Tornado x1 92mm 119CFM very loud
Tornado x1 88mm 84CFM oh so god forsaken loud
Wife x1 50mm yackbox god so talks so much about my visa bills...
having the Tornados on at the same time, and not hearing what the wife has to say?
PRICELESS ! ! ! !! ! ! ! !! ! !! ! ! ! ! ! !!
