Silvestre said:mine runs stable at 283x8.5 using Winnie 3000+ and G.Skill1GBLA 283MHz 2.5-3-3-7...this memory is funny...only needs 2.6V to run like stable like that...
prime for 5Hrs and it was okay
g0dM@n said:Wow you're on a half multi? Isn't that going to offset your RAM speed?
The 1.36b bios has a +18% setting. Personally though If you can get that far on stock why bother with the voltage?g0dM@n said:Awesome... Thanks for the info.
The thing is that I can do 278x9 rock stable at DEFAULT voltages. My CPU has an XP90 and 92mm Stealth over it, which is useless since I'm at stock voltage still (kinda amazing if you think about it --702mhz overclock with default voltage). Maybe I can try 300x8.5 = 2.55ghz, then RAM would be 2550/9 = 283mhz, right?
Maybe I can try that out or something... the highest this mobo is letting me go is 1.45v + 10% = 1.61v. I tried that on 300x9 and I don't know why it's not stabilizing. I did a burn in at the lowest semi-stable boot (1.40+8.3%) at 300x9 and did a burn-in overnight. I figured that would help me push 300x9 with a high vcore, but no go =(
