Samoyed said:I like the mod too. It's creative and cheap. BTW I looked for copper staples at Home Depot. They didn't have em. I modded my 6800GT (Leadtek) huge copper sink by gluing aluminum spikes I cut off of another sink. I glued them onto every available bit of surface area left and then attached a 73CFM fan to it. With room temp at 72F and the case open I only get idle temps of about 43C and believe me this sink is using arctic silver 5, is massive with a mad fan and an additional smaller fan on the back copper plate (Yes is has a copper backplate). You can't get a better sink than what I have now. Question is Who's temps are wrong? Either my heat sensor is wrong or his is wrong.
Samoyed said:Well the scientific priciples are there for an expert to predict the best likely config for a heat sink and also predict what type of performance you might get from a particular design. 9000 Seemed to think that the Leadtek sink was substantial but the fan very weak. This is the first video card I have ever held that could be used as a blunt force instrument it's so heavy. Keep in mind I simply
1)added AS5 for the thermal paste
2)added more fins even if they are aluminum and glued on with AS5 epoxy
3)added a small fan to the back plate
4)added a vacumn cleaner strength fan to the sink.
5 added and exhaust fan to the PCI slots next to the card for additional venting
Right now the room is 72F, case temp an alleged 33C and the core 51C typing this.
Case has 2 80mm fans blowing in and 2 80mm blowing out and no CP U heat in the case due to H2O cooling
