- Sep 26, 2009
- Mojave Desert
Hi Everyone,
been lurkin' for awhile here and finally getting around to building a new 'puter.
but i have a question about cooling this thing.
here's what i've managed to gather....so-far...
ASUS P6T7 WS Supercomputer Motherboard
Intel Core i7-920 CPU
Apogee GTZ Ci7 Waterblock
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM SATA 3.0Gb/s
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s
CORSAIR TX Series CMPSU-950TX Power supply
ASUS Black SATA 24X DVD Burners (Two)
Swiftech MCP355 12 VDC Water Pump
Corsair Obsidian Series 800D Black Full Tower Computer Case
on the side there's a Zalman reserator to be used as a resevoir.
(if possible)
The Reserator is a left over from a previous build, and i figure that it might be a good idea to use it since it's here.
but what i'm trying to do (if possible), is to put a 3X120mm radiator along with 3 120mm fans, in the top of this case. not sure if it's posible. but if so doe anyone have any suggestions?
i was looking at the Swiftech MCR320-QP Quiet Power radiator that newegg has for cheap (customer reviews are good), but they out of stock 'til mid july.
any suggestions would be great.
thanks pr2112.
(if possible)
thanks pr2112.
