- Thread Starter
- #41
Or can hook up the case outputs for speakers and keep headset connected directly to the back of the card.
you mean connect the speakers to the Realtek built-in ? but I disable it before even inserting the xonar.. (?)
Looks good to me, just be sure if there is a fault with a product or so, you will be able to return it
I've been using a logitech g930 for 2 years now. I will never go back to any other headset unless something better comes out for the same price. It also took a major price hit down to $80 so it's a great headset for relatively cheap. I tried a astro gaming a40 and couldn't even get it to work (still have no idea why) so I sent it back for a refund. $300 was a little much for me to spend on a headset anyway even if it had considerably better sound performance than the g930 (so I read).
Yes the VG248QE panel is a lightboost panel. Just use ToastyX utility to switch to 120Hz strobed(lightboost) when playing fps games, or leave it on if you want for all your games! I just found it most prominent in FPS titles.
With ToastyX though you can use a keyboard shortcut to change between 144Hz and 120Hz + Lightboost on the fly.
As for the pc360, just be sure you prefer the open-aire design to the closed. Outside of that glad to hear it's coming together.
Almost forgot to mention, for your VG248QE, be sure to check out these settings on the monitor OSD:
Splendid= Theater Mode
Sharpness= 40 (eliminates some minor fringing on text – also use ClearType)
Brightness= 54 (according to preferences and lighting)
Contrast= 43 (default contrast in this preset gives major shade crushing)
Color Temp= User Mode
Red= 100
Green= 95
Blue= 93
Should help liven up the screen from the out of box look
You actually can just leave it set to 120 + LB, you can also adjust the Lightboost % on the monitor OSD (10% is best for smoothness), just keep in mind Lightboost % dims the monitor the lower in % you go.
For the sennies, I myself personally prefer the open-aire, however, the bass is weaker compared to the closed cans. Keep in mind, that is true with headphones in general anyway. But, overall the 360s have a larger sound stage, crisper mids and highs, and an overall better sound assuming you can handle the lack of isolation.
1) The 360's will be similar in reference to siberias as far as isolation goes.
2) In short, this is the way it is between open and closed cans, closed you get more bass with a smaller sound stage, but open you get more sound stage with less bass (but the bass is more refined). I'm not saying there is no bass, by any means, just don't expect it to be thundering.
Lightboost dims the monitor, as it was meant for 3D with use with 3D Glasses. You'll see when you get the panel what YOU like, you can even find a middle-ground between lightboost @ 40% or 50% if you want as well. But, 10% makes full use of LB.
