- Jun 22, 2005
You will not need to enable 3D Vision unless you have a 3D Emitter and 3D Glasses. To go to 120Hz or 144Hz, right click desktop -> Properties, then click Advanced Settings, click on the Monitor tab, and just change the Screen refresh rate accordingly.
As far as Lightboost, someone made a utility that made Lightboost a breeze to turn on and off. You can find it HERE under the titled "Easy LightBoost via ToastyX Strobelight App" towards the top of the page. With it you can set certain refresh rates from the dropdown menus, I myself use 144 and 120(Strobed).
Your 560Ti will work no harder than using any other 1080p monitor, it's just that now when you play games on the panel, your monitor will be able to "show" above 60 FPS.
As far as IPS vs TN, I own both, so I will say it's circumstantial. I would not be running a 27" IPS or PLS panel on a 560Ti, that I can tell you.
