Front of your case
What on earth xD
Give me a moment to wake from my laziness, Im skipping classes today waiting for exams next week lol. I think I saw a cheap little audio out bay slot
I was thinking of the Essence, not the Phoebus for front panel. You just planned on using your speakers for front panel right? Not the headphones?
If yes, then do what was mentioned by someone else I believe, use onboard for speakers as the easiest alleviation.
Direct-interference, no. You will just need to set the Phoebus in Playback Devices as the Default. I know Raja over @ RoG keeps saying remove anything and everything else audio related, and while I have not tested onboard while running Phoebus I have consistently run NVIDIA's HD Audio through HDMI and it has not messed with the Phoebus.
Running both will also give you the option of setting seperate volume levels, 1 of headphones and 1 for speakers.
I just have my mic set to 96 / 24.
As far as the Phoebus app profiles, I BELIEVE, I could be wrong, but I believe the HI-FI setting removes extra sound adjustments. Which is where it is recommended. Anything as far as EQ you can just edit in DHTv4.
If you feel you LIKE the sound with any of the Intelligent EQ options, by all means use it! It is what sounds best to YOUR ears, as everyone perceives sound differently.
Pic below included for what I used with my HD598's.
