I spent several hours last night and today looking into google 'cpu coolers aio'.
Most, if not all the reviews contain words like "came in a black box with blue highlights", "three customizable color themes", "clear tubing with customizable colors to enhance your visual experience", "customizable led lighting theme", etc.
I did not find one review that measured the ability to remove heat.
I have an area under my work table for the tower case. A small sized room fan moves air there. If I put $$ into a case with "clear inlays for visual ..." and $$ into one of these "enhanced visual experience" cooling kits, I have to sit under the work table.
I look into my tower case every 2 to 3 weeks with cleaning tools. Other than that, the tower provides mflops for my above-table, real-life experience.
A few years back, I exeprimented with a dual loop cooling system with TEC's on the outter loop and higher clock rates. If I stayed above condensation, my idle CPU temps were in the 30 C range, althoough the clock was higher. At full load, I saw temps in the 80 C range. OK, that is doable. For my daily use, 4.2GHz is enough. I run this system 24/7.
Where can I find real reviews of AIO systems? I believe they are on this forum, I just can not seem to find them. Blind in one eye...
