My reset button on my case doesn't work - should I try it directly on the motherboard???
I had a situation the other day on my desktop where I had removed the video card and was using the onboard video for about a week. When I put the video card back in I got no video. Took it out again, check bios video settings and put it back in. Still no video. I knew there was nothing wrong with the video card. To make a long story short, the video mode was not switching from onboard to dedicated like it should have. It was hung for some reason. What finally fixed it was hitting the reset button several times.
TBsteve, if your reset button isn't working it makes me wonder if you have the front panel connectors on the wrong pins in the block. I would check that. Typically, the end pin on the longest row is unused. It's easy to bet things misaligned. Check your manual.
One other thought. Do you have a large, heavy aftermarket tower cooler installed? If so, was there any point in time in your haste to get out of Dodge that the case may have fallen over or been dropped? With both USB and PCI-e not showing up it occurs to me that the socket area may have been damaged by trauma.
I think I have a Hyper EVO 212? IDK. If its the CPU/Motherboard does that mean time for a new build?
It would be a good time for upgrading, yes. A new direct replacement motherboard to stay with your current hardware platform is about $280 by itself and then you are still on a technology platform that is four generations old. But an upgrade would mean new motherboard, new CPU and new RAM. All the other current stuff you could reuse.
- - - Updated - - -
Also, my friend is going to come take a look...but he can't until probably Friday because of the hurricane. Dam you hurricane
We'll be glad to take a look at it for you and offer advice. Yeah, you can do a screenie if you want and attach using the Go Advanced post button to upload the captured file.
Sorry, what exactly do you mean by that? By AIO do you mean all in one? And what do you mean by custom loop? Sorry man I'm a rookie.
I definitely would upgrade the water cooler you have listed. That is a puny unit and will likely not provide enough cooling for the 7700k. It probably would not provide any better cooling than your current CM Hyper 212 evo or maybe even not as much.
If you want to cool that CPU with an AIO water product, pick one with a 2x120 radiator.
Did you pick that case because it came with a PSU on a combo deal? That PSU is not as good as the one you have now. As I recall you have an EVGA Super Nova now, correct? That is as good a PSU as there is and it's only a year old.
Rest of the stuff looks good. Realize the the m.2 SSD you have on the list is SATA and not PCI-e (nvme). The latter will give better performance but is more expensive.
Motherboard and memory and video card look good.
So I guess I don't understand why you are not reusing your case, PSU and your existing SATA drives?
