Awesome. Ah okay. Yes, I think I'd rather get a AIO water cooler first. Next build down the line I will give it a shot making it myself. I think I will be waiting until Friday for my friend to look at it. I'd like to narrow down the issue possibly so I can then sell the rest of the parts. Going to sell my monitors as well so I can stick to the one Samsung monitor I have in my cart. Is water cooling a good option for me or do you think I should stick to good ol' fans? Certainly, AIO water cooling is an option for you. But so is a good air cooler. It is up to you. If you go with air instead of water get a top end air cooler like the Noctua NH-D15. https://www.newegg.com/Product/Product.aspx?Item=9SIAADY44C6006 They are huge but will give about the same cooling performance as a 2x120 AIO water cooler. One of the main reasons people go with an AIO water cooler is to free up space in the case. It makes it easier to work on things inside the case when you need to.
Also; reviews on the CPU I chose pretty much have a consensus that it runs hot. Do I need to have a heat sink or does water cooling take care of that? Water coolers use a "block" that mounts on top of the CPU and acts as the heat sink. With AIO coolers the water pump and the block are a one piece unit. As water in the block absorbs heat the pump pushes the warmed water through the intake hose up to the radiator where the fans on the radiator remove heat from the water by blowing air across the radiator fins. The warm water enters in one side of he radiator (which is the heat exchanger) and the cooled water exits via the return hose to the pump/block.
Also stupid question, should I get a higher wattage of PSU or should I still be good with the Supernova 650 with a 1080 and overclocking?
