- Aug 14, 2014
Hello there, the time has come for me to upgrade my old PC, along with the i5 3570K that has served me well admittedly. But altogether my old system just wasn't cutting it. So I decided to splash out on a new build. Here is a rough idea of what the finished rig would look like (note that I will go into an explanation a bit later on about the title of my post).
CPU: Intel i7 5930K or Intel Xeon E5-1650 V3*
Cooler: Corsair H115i
RAM: Corsair Dominator Platinum 32GB (4 x 8GB) DDR4
SSD 1: Crucial MX100 256GB (Already Purchased)
SSD 2: Samsung 950 Pro M.2 512GB (this would be used for the OS (Windows 8.1), Sony Vegas of course and other intensive applications)
HDD: Western Digital Black 2TB (Already Purchased)
GPU: MSI GTX 780 3GB VRAM (Already Purchased)
Motherboard: Asus X99-A
PSU: EVGA SuperNOVA 650W 80+ Gold (Already Purchased)
*So my main issue is really here (although suggestions elsewhere would equally be welcomed). I have approximately £500 to spend on a CPU and and can't really go over that if I want to be able to afford this build. My main problem is the choice between the processors. I have visited many websites on the subject of i7's vs Xeon CPU's when it comes to rendering and I see a mix of Xeons will be better by default, i7's will beat Xeon's 1v1 but a Dual CPU set up Xeon's will crush the competition. I unfortunately don't have the budget to fork out £1000+ on a High End CPU(s).
So I thought if I could get some suggestions on what would be the best with regards to Xeon or i7 CPU's when it comes to rendering HD footage (since I mostly work on 2K projects). But for family as well I might need to quickly blitz through a 1080p home video. Or even if I should get another processor separate from the 2 I listed altogether. Any suggestions are greatly welcomed.
I mean from what I've seen of the 2 Processors above according to CPU Boss the Xeon beats the i7 when it comes to using both single core or all cores together.
http://cpuboss.com/cpus/Intel-Xeon-E5-1650-v3-vs-Intel-Core-i7-5930K
And you also have the Xeon's natural ability to cope with really heavy workloads. As they're designed for Servers/Workstations they can take that bit more.
But then Passmark seemingly gives the Xeon a lower rating.
http://www.cpubenchmark.net/compare.php?cmp[]=2389&cmp[]=2336
Really not sure what to go with. I'm being drawn to the Xeon myself.
I should mention my budget is around £1200 for a Motherboard, M.2 SSD, CPU, RAM and some type of cooling solution (whether that be Water or Air). I can probably stretch the budget to about £1250 if I need to.
