- Jun 9, 2002
According to Asus: "With x4 PCI Express 3.0/2.0 bandwidth, TUF X299 Mark 2's dual M.2 supports up to 32Gbps data-transfer speeds." I know, the key words are up to, but from what reviews I read it sounds like these Asus X299 boards allow a full 4 lanes on the PCIe 3.0 bus.
Ok, I have the m.2 mounted and I found a heatsink that will work. Should I center the sink or crowd one end or the other?
Sounds like you should be good to go with dual drives at full bandwidth then.
Ideally you want to sink only the controller, but without seeing exactly what you're working with it's difficult to say. For my own drives I put 4 small sinks, one on each corner of the phison chip.
