- Jan 12, 2001
- Kansas, USA
- Thread Starter
- #81
While we wait for Neb to answer... my PCH temp seems to climb to 42 and then stay there. I have pretty good case flow.
How do you read the temps of the SSD? I have a fan controller with thermistors. I put one under the drive in about the middle. I have a large sink on the m.2 that seems to be working well. The highest I've seen is 34 C (I know that's not the controller temp). I do have a temp on the motherboard called PCH that I'm not sure what it's for.
I ran Crystaldiskmark, I have no idea if it's good or bad.
Those numbers are sick. The 960 Pro is definitely a nice drive. Some of the benchmarking performance is the result of trickery(for lack of a better term), but it's probably the best performing m.2 drive out there overall. Just wish they were cheaper. At right around $.59/GB they're definitely priced at a premium.
Turns out my drive...the MyDigitalSSD BPX is incompatible with my new MSI x399/TR 1950x rig...so it'll be relegated to my Z270 rig and it's back to the drawing board for selecting an m.2 drive for the new build. I think it's down to the 960 Pro(1TB)($579) or the Plextor M8peG(1TB)($436). The Sammy is definitely faster overall, but with a shorter endurance and a 33% price premium I'm leaning toward the MLC based Plextor at this point. Both are on MSI's QVL...so should both work with the MSI x399 motherboard.
Since you’ve got the space consider some cheapo XG3s on eBay. They’re hot as a mug sure but that can be controlled and everyone is unloading them because they’re overheating in laptops for NOTHING!
Saw one 512gb with multiple available for $155 which is absurdly cheap for a good MLC nvme drive
$299 for a 1tb drive!
http://m.ebay.com/itm/Dell-Toshiba-...%3A02f54c5f15e0a9cb9feee6b3fffa541e%7Ciid%3A1
I got my Evo up to 53C after a couple minutes of non-stop sequential reads. How does that sound temp-wise?
The pic is toward the end of 1 battery of tests. It seems high speed sequentials heat it up the most.
I notice in Windows 10 there's always something writing at least 30 KB/s to the damn thing. Sometimes it's as much as 70 KB/s and in many cases it's unidentifiable system stuff being written to the NTFS Volume Log or some such thing. But I also noticed the M$ Edge browser loves to also constantly stream write while idle, in perpetuity. I've also noticed Cortana doing the same thing. I elected nay for many Cortana things but did not yet hunt it down and destroy it. Either way if I leave the system on 24/7 I can expect 1TB - 4 TB writes per year. Not good for an Evo
Eventually I plan to hunt down and destroy every last trace of needless writes. I'm sure it will be very educational, even if much of it amounts to nothing.
eBay is an awesome place to pick up nvme drives as people like me are the ones dumping them there. I honestly cannot think of a single drive that doesn’t throttle to one degree or another on a laptop. The only ones I haven’t seen do this are Macs that integrate the heat sink into the controller plus they use a low power custom SOC to boot.
The only downside is do not buy anything using smart post or ups post. They take forever and while I am happy I found a 5400s to raid with it has taken 12 days so far to arrive and it still isn’t here.
If I had a desktop I would totally buy an OEM drive that was rejected because it overheats
The advantage is while the drive by itself isn’t great if you can get a 512gb drive for $150 and you’ve got a board with 3 slots for $450 a well cooled xg3 in raid0 x3 (1.5tb) will smoke anything out there and will be cheaper than a single 960pro 1tb
The trick is keeping them below 50C* before stage 1 throttling normally starts which should be no problem.
Just wanted to report back after using the Samsung 960 Pro as the boot drive for a few days. It's working great, I love 15 second boots into Windows. Good air flow and a sink are critical to the longevity of this drive. I'll repost the photo of the heatsink I installed onto my m.2 drive (lower left corner of the photo).
I ran CrystaDisklMark again using HWinfo to monitor temps and max controller temp was 66 C (that was only a spike at the very end of the bench). Most of the time temps stayed in the low to mid 50s. I did see low 60s on the very last bench. After hearing of that some folks were seeing 90+, I feel like my heatsink was working quite well. It's a Thermaltake RAM sink that is held on with thermal tape and zip ties (ala the Nebulous method).
Ok, I moved some cables around and zip tied them out of the way for better flow from the front fan to the m.2 sink. I also set the lower side panel fan speed from medium to high. I ran the bench again and this time I had a max temp of 64 C, again only towards the end of the benchmarks. Most of the time it was high 40s to mid 50s. From what I've been seeing on the boards, an occasional spike into the mid 60s is pretty good compared to what others are getting with this Samsung drive. I'm seeing lots of people complaining of hitting 90 C. I think it starts thermal throttling at 90, right?
