mart199020004
- Jan 22, 2014
hi,
I've recently build a new pc SPEC's are as followed
amd fx8350 4.0hz (standard cooler)
Coolermaster K350 Case
CM Elite 500W PSU
Corsair Vengeance 8GB (2x4GB) DDR3 1866Mhz Memory Kit CL9 1.5V
Asus M5A99X EVO R2.0 990X Socket AM3+ 8 Channel Audio ATX Motherboard
The pc runs fine with normal pc activity 30 and 45 degrees c
whilst gaming the cores stay between 50c and 70c (amd overdrive and core temp) , but my issue is behind the motherboard and on the top of the case gets really hot, where you can feel the heat coming though the case
all setting are standard all set to default
all idea on what could be the issue?
many thanks martyn
CM Elite 500W PSU
many thanks martyn
