- Nov 9, 2012
- Aberdeen SD
You seem to be spending alot of money just to "destroy" your friend. It is your money and if that is your only goal, it is your right to spend it on that reason. My question to you is what is the gain in it? You have made no mention on the resolution you play at, games you play, and what type of monitor you have. That is a HUGE influence on what is best.
If you only intention is to have a better computer than him, you are starting off on the wrong foot with AMD. Spend the same on a nice Z77 board and an i7 at minimum, but i would advise atleast a I7 Extreme. Next skip those silly 7970s and go for SLI or Tri-SLI Titains.
The point I am trying to make is somebody is always going to have a faster rig. Flexing the Epeen is nice, but once its flexxed and your playing WOW at 500fps on a 60hz 1080p monitor whats the point? Looks the same as somebody getting 60fps but they spent much less.
Build for what YOU will use it for, and you will spend less for the same experence.
But to answer your question, 8350 is faster.
