- Oct 17, 2014
Hi, could you help me make my computer as cold as possible, as it's overclocking friendly, and I plan to keep it for a while. Budget isn't that limited, maybe 150-200$ Newegg/NCIX (Canada) direct links welcome.
My current case: http://www.newegg.ca/Product/Produc..._re=rosewill_blackhawk-_-11-147-107-_-Product My current heat sink: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103099
Hopefully I didn't invested in a bad case? Are the Rosewill fans that came with the case good enough, or should I replace them? (I want to have the maximum number, namely 10)
Other specs: ASUS Rampage IV Extreme
Intel i7 4930 G.Skill 16GB DDR3 2x Gigabyte GTX 980 4GB 750W Rosewill PSU
