- May 12, 2005
- Home... again
This is sweet on thunderbolt !
Good job and thanks.
It's not a blending issue, I'm sure of that. This is the skin our skin started from:
http://www.webhostingtalk.com/?styleid=21
Edit: I can make the post content area grey and it appears with rounded corners, but when I do that the username and avatar fields get a white background. The way I'm doing it now, they both show up with grey backgrounds, but they have square corners. I will probably need help to figure out the CSS classes/styling I need to apply to get the corners to look perfect.
The setting that makes the corners square is this:
li
background-color:#333332;
I can delete that background-color setting, and the post content area then shows grey with rounded corners, but thats when the avatar and username fields show up with a white background.
In theory I think what you would need to do is make the outline a pix thicker and make it sit on top of the solid grey background.
I am not complaining, I LOVE IT!! Thank you!!
Making the outline gray as well made the 90 degree corners of the background a lot less noticeable. There has to be a real fix though...I liked the light gray outline. How do you preview html code, just rename your .txt to .html?
Yep. basically XD
Thanks, that was pretty much it and I got it working.
