- Feb 27, 2013
- Soviet Canuckistan
Hi Guys,
So I've been out of the overclocking scene for years now, and haven't really done any serious tweaking since working at a computer store during college in the early 2000s. I recently (as in, last night) bought a new mobo/chip/ram/PSU combo and figured it'd be fun to get back into tweaking and OC'ing again.
Last time I did this, things were much simpler. Your RAM and the bus it was on ran at a certain speed, so you'd set the RAM bus speed, set the multiplier, and RAM Speed * Multiplier = CPU Speed. Simple enough. Play with the voltages and memory timings a bit and you were done.
My new setup is an AMD FX-8320 on a Gigabyte GA-970A-D3 with 2x4GB of Corsair Vengeance 1600MHz DDR3 , and I have to admit I'm a little lost on it. Now it looks like there's the RAM speed, then the IMC (Integrated Memory Controller?) speed which is different, and then the multiplier, and somehow they end up determining your CPU speed.
What I'm trying to figure out is how much room my 1600MHz RAM gives me for overclocking, and how the RAM speed and the IMC speed relate to each other. What is the "stock" setting for RAM, IMC and Multiplier with this chip, and how does changing one (say, RAM or IMC) affect the others?
I found something saying the IMC runs at 2200MHz, but I can't imagine the system would require 2200MHz capable memory in order to run stock clocks, so what gives?
Jon
Jon
