Well, I've been looking into my memory of late because it's one area of my system I've not taken much notice of until now.
Running the following:
Gigabyte GA-7N400 Pro2
AMD Athlon 2800+ Barton
2x512 DDR400 and 1x256 DDR400
I have a couple concerns, I'll explain the Overclocking one first.
12.5 x 183 - 2.28Ghz, so memory is at 366. FSB can't get much higher, 183 is 100% stable though.
My concern is that to the best of my understanding the memory should run at 400. I've played with the multiplier and had the CPU running far less than 2.28 but it will not take much more than the above, let alone 200 FSB without booting assues.
So, I got the CPU-Z thing to find out what exactly I'm running, It's been awhile, the memory actually missed the last upgrade, hence the 2x512 and 1x256, had another 256 but the board will not boot with 4 double sided sticks, hence the 3, just used what I had. I found the following...
The 2x512's are Nanya PC3200, the 256 is Hyundai PC3200.
All I know is that I understood it to be Samsung, it's been a few years, never heard of Nanya and didn't know Hyundai made memory.
I once played with the timings, the default is 3.3.3.8 which know is not great from what I've read but last time I played with it I got sick of removing the battery to reset the bios everytime It screwed up.
So in conclusion I'm hoping someone can clear this all up.
Is there a big hole in my overclocking techniques, is my memory so crap that's it explains the overclocking issues and should I even bother playing with it anymore than I have?
I'm planning an Upgrade at Xmas but funds are limited, getting the following.
Gigabyte K8NS 939-Ultra
AMD 64 3200+ Venice
The other question is memory, I don't know if I should keep the current 2x512's, replace them or get 2 new ones and try to run 4x512. I can't really afford 2x1gb sticks but keeping the current ones for now and saving is an option if Nanya isn't all that bad.
Sorry, this got really long but if I can sort this confusion out now I can avoid the same mistakes in the next upgrade.
Included the CPU-Z file just in case it helps.
Thx in Advance.
Vas.
AMD 64 3200+ Venice
Thx in Advance.
Vas.
