I ran memtest86 v1.40 (because my system was crashing) and this is what I got:
1. used both ram sticks on Dimm1 and Dimm 2, memtest86 failed on test#7 [Random number sequence], on the 14th minute.
2. Used only one stick (Kingston Value) in DIMM1. Test failed on test#7 (again) on the 8th minute.
3. Used my other stick, which I think was Kingston too, but I just don't see "kingston" anywhere on the stick. (I think I put it in DIMM2) Test failed on the same test #7 on the 7th minute.
4. Used the Kingston stick in DIMM3 - test failed on the same test#7.
I don't know if all this means anything. Please someone tell me if the problem is clearly in my RAM. (Kinda strange for both sticks to be bad though..) Should I run more tests?
