the warping is probably due to the weight of the zalman. according to their site, the max weight for a Intel P4 and AMD 64 cpu is 450gramms, while only 300gramms for an AMD socket 462 CPU. the CNPS7000-Cu weighs 773gramms, so its well off spec. not only is this dangerous to the CPU, meaning you must take care when moving the machine, but this also means theres more weight pushing in on the mobo. now in a tower, you would think as much weight would be pushing in on it, although you may have the bolts too tight. this is why i like the thermalright coolers. not only do they perform well with a high flow fan, but they also come with a backplate. ive though about it and since my board has the back plate on, i dont think the mobo wall fan will do much good since the backplate is covering the socket, and so it would block air from directly getting to the back of the socket.
