jsmith2000
- Mar 20, 2018
I have a ViewSonic VA1938w-LED monitor. If I plug in the monitor signal cable to a desktop and the power cable to an outlet (the desktop has nothing but the monitor connected to it and it is NOT plugged in.) and check the computer chassis with a neon light tester, the light comes on, indicating the chassis is energized, albeit low voltage.
If I take another ViewSonic VA1938w-LED monitor and plug the signal cable to another desktop computer, which also has nothing connected to it except the monitor, and check it with a tester, again, the light comes on, indicating the chassis is also energized. This is a different monitor (though same brand and model), different signal cable, and different desktop. Yet, in both cases, the computer chassis are energized.
The only way I can think of for the computer chassis to be energized is the power somehow goes from the monitor through the signal cable to the desktop computer.
I wonder if this is by design or there is something wrong with the mother board or something.
