- Jul 12, 2002
As the title says, my monitor won't turn on or come out of stand-by mode during start-up. I have to unplug the DP cable and replug it and then it turns on.
I have tried messing with some settings because recently I reloaded recommended settings on my mobo to troubleshoot something else, so I'm not sure if I had a setting in there which prevented the above.
I've tried auto/PEG mode in bios and I've just used nvidiaprofileinspector to make sure single display performance mode is selected instead of multi (since nvidia removed this feature from the 3d basic settings)
I did purchase a new DP cable recently and have been using it but the issue happens only sometimes so I'm confuzzled. I've not switched back to my original DP cable that came with the monitor instead to see what happens.
Any suggestions of what could be causing this?
I do run dual displays off my single GPU but I don't always use my 2nd display, and when I do, I use extend displays mode in windows.
Thanks.
Thanks.
