QuietIce
Disabled
- May 7, 2006
- Anywhere but there
No X6's in Europe ...?
That depends on what applications you're running. If it's anything that will use all six cores that's a 50% increase right there. If you're running apps that can only use two cores then all your choices are probably overkill.well there are but im not sure about the difference between the one i choce and the few above it, and i'd like to stay below 500 euros for the cpu, mobo, ram package
well whaddya know, i did a re-check and with the Phenom II X6 1055T, AM3, 2.8GHz my total is 470 + shipping
whats the diff between 955be and 1055t? huge i'd imagine ^^
That's what we're paying over here in USD ...!1090T 296.00 €
http://jimmspc-store.fi/tuote/HDT90ZFBGRBOX
1055T 205.00 €
http://jimmspc-store.fi/tuote/HDT55TFBGRBOX
Thank goodness, the components are semi still understandable
Prosessorit
Yeah. Im USD. I live in Missouri. I was just helping him find the X6 processors from all the stores he linked that lets him use paypal while answering your question at the same time
one thing still puzzles me is the intel package, friend said that with the i5 750 i'd be using low volt ram ie. the 1.35 g.skill eco i've chocen, cause if the ram volt is too high it might burn the cpu, but if this is the case... hows the situation with amd?
thanks alot for your answers so far guys, really appreciate it
Some games (GTA IV, IIRC) use all the cores you can throw at them, which is why I asked. But if going with the X6 seems excessive I'd wonder why you would bother spending the extra for an i5??Well mainly just playing and "normal" end-user stuff, no audio processing or graphic designs or video encoding. just playing, watching movies etc... hence thats why i thought about the 955BE instead of the 965BE cause the price diff is 20 euros and thats quite alot, because what i've read and how i understand it. the diff. between the 2 cpu's is negible (if im spelling that right *sigh* sorry about the grammar) so at first thought i figured an 4 core cpu would fit me... just dont know do i go amd or intel, is it just do i prefer vanilla icecream over double chocolate fudge icecream.
When it comes to system specifics, AMD and Intel are very different. RAM does very well at the standard 1.5v and I've seen guys with it cranked up to 1.75v without a problem (for the CPU). Must be some quirk of Intel because I've never known RAM voltage to burn out a CPU. Maybe it's because AMD vCore runs higher (though the power consumption isn't higher). If anything AMDs prefer at least 1.50 vDIMM and some boards won't let you run less than that ...
955 BE = 3.2ghz
965 BE = 3.4ghz
They both have unlocked multipliers, so five seconds in the BIOS and the 955=965. The 965 might be able to clock a bit higher as it's been branded a faster CPU, but you never know, you might get a golden 955 that will hit 4ghz too.
It's a toss up really. The Phenoms do run a bit colder than the i7s...not real sure about the i5s. That too is a wash though with the Phenom IIs as their ideal operating temperature is also cooler. Your going to be fighting heat either way.
With the Black Edition 955 you could probably just up the multi a couple of notches and be at 3.6. Probably wouldn't even have to raise the Vcore. It's that easy.
Almost all of those vertical coolers will allow RAM to fit under them if it's not high profile RAM, which yours isn't. I can't comment on the NH-D14 specifically but it would be odd if it were designed differently. I know for a fact the TRUE will allow normal RAM to fit under it ...
http://shop.e-bug.de/shop/product_info.php?info=p292339&refID=ffs
http://jimmspc-store.fi/tuote/ULTRA-120-TRUE-REV-C
the only difference between the 955 and 965 is that the 955 is 3.2 Ghz and the 965 is 3.4 Ghz. The only other thing this effects is that the stock voltage of the 955 is a little bit lower. If you are gonna overclock them then it doesn't matter and you may as well get the cheaper one. It will literally take 10 seconds to get a 955 up to 965 speeds. (excluding stability testing). And yes, Phenoms run cooler than i5/i7, but i5/i7 are designed to handle higher temperatures so you can't really compare them. Except as to how fast they will heat up your room
Depending on which model it is that's not necessarily true. From AMD's processor page:the only difference between the 955 and 965 is that the 955 is 3.2 Ghz and the 965 is 3.4 Ghz. The only other thing this effects is that the stock voltage of the 955 is a little bit lower.
HDZ955FBGIBOX (C2) 0.875-1.5V
HDZ955FBGMBOX (C3) 0.825-1.425V
HDZ965FBGIBOX (C2) 0.850-1.425V
HDX955FBGMBOX (C3) 0.850-1.40V
HDZ965FBGMBOX (C3) 0.825-1.40V
I don't know what the deal is with the X955 instead of Z955 - that's a new one on me. Maybe something sold in Europe or Asia ...?
