So there is nothing I can do to get the results above on my old Windows installation?
Nuking my C drive is the only solution?
All right, so what happens if I do a fresh install on this SATA II SSD and I image it and and use the image to move to one of the newest latest SATA III drives out now? Am I still looking at performance differences or does performance drop only apply when you move from a mechanical drive to SSD?
Actually the both tests were of the same Windows 7 C Drive partition.
Notice how much better it was when I ran it *from* Windows XP on D Drive. Both tests were of the same Windows 7 C Drive partition.
My question is: would the speed also increase on freshly installed Windows XP - or only on freshly installed Windows 7/Vista?
...but there is one thing you can do for Windows XP and SSD:
You cannot do this if you only have Windows XP but you can do it if you have Windows XP AND Windows 7 or Vista dual boot.
So then, you boot into Windows 7 or Vista and run ForceTrim FROM there. So you run ForceTrim FROM Win7 ON your Windows XP partition:
http://www.ocztechnologyforum.com/f...Here-s-a-tool-to-force-TRIM-your-entire-drive
