ShawnTRD said:Anyone had a problem with this motherboards GigaLAN not working? I've tried everything I can think of. I even reformatted XP. The network device shows that it's working, but it's not receiving any data.
rseven said:ShawnTRD, I have usually used the Nvidia LAN as it does not require additional drivers other than the NF3 platform drivers, but the GigaLAN has worked fine when I have used it. Have you installed the additional drivers and is it enabled in the bios?
rseven said:I think I originally got them from Nvidia, but they are available here.
http://downloads.guru3d.com/download.php?id=19
rseven said:Yes, so far as I know it has never changed regardless of what bios version you use. That would explain the freezes.
||Console|| said:Seams like I need to run a old bios to get higher vcore . ( will the old bios work with a x2?)
If any one is running the 1.c3 Sideeffect bios and can get higher than 1.55 v plz let me know how you do it .
Thats what the math works out to but it doesnt seem to work like that .ShawnTRD said:1.4v set in bios reads ~1.36v
1.425v set in bios reads ~1.39v
1.45v set in biose reads ~1.42v
3.3% + 1.4v in bios reads ~1.42v
3.3% + 1.425 set in bios reads ~1.44
3.3% + 1.45v set in bios reads ~1.47
5% + 1.4v set in bios reads ~1.46v
5% + 1.425v set in bios reads ~1.49v
5% + 1.45v set in bios reads ~1.52v
8.3% + 1.4v set in bios reads ~1.52v
8.3% + 1.425v set in bios reads ~1.55v
8.3% + 1.45v set in bios reads ~1.58v
10% + 1.4v set in bios reads ~1.58v
10% + 1.425v set in bios reads ~1.61v
10% + 1.45v set in bios reads ~1.64v
maybe a bios flash will help||Console|| said:Thats what the math works out to but it doesnt seem to work like that .
I run mine @ 1.45x10% and it only shows as 1.55 in bios and same in cpuz
even if i put it on 1.55x10% still onnly shows 1.55
