- Feb 1, 2009
- Illinois
Well, just like the title says, I am having problems with my set of Mushkin 996657 (2x2Gb DDR3 1600 @ 7-7-7-20).
I basically had problems from the beginning, but they went away with a voltage increase or at least happened less often. Recently though, that has not been the case. I normally leave my computer on 24/7 but have been coming downstairs to find it at the windows screen after a reboot. Upon logging in, I receive the "Windows has restarted due to a fatal error" crap. I decided to get memtest86 v3.5 and run and low and behold, they error out in the second test (Test #1).
I tested them individually over night at all stock settings in the bios (1333 with 8-8-8-22-30 timings; 1.6volts) They both passed failed. So I cranked them up to 1600mhz with 7-7-7-20-28 timings and they both once again failed. I proceeded to dual channel testing.
It went a little something like this: At above manufacturer suggested settings (1600mhz with 8-8-8-22-30 1.95volts) they failed in dual channel mode, either pair of ram slots. But I noticed that they failed every time between 45-48% on Test #1. I got around this by using configuration to run the tests one by one and this is how that went:
Test 0, pass.
Test 1, fail.
Test 2, pass.
Test 3, pass.
Test 4, pass.
Test 5, fail.
Test 6, pass.
Test 7, fail.
Test 8, pass.
Test 9, pass.
I then went into windows and ran all three tests in Prime95's array. Small FFT's is the only to keep running. Large and Blend both resulted in instant freezes.
Finally, I want to mention that the Bsod's and freezes in windows don't appear to have anything in common. Sometimes it is doing nothing but idling at the logon screen, other times while my mom is browsing in IE and occasionally while changing a song in itunes. It was something I could blow off before, but as it becomes more and more common, I am beginning to get upset with a set of ram that should run 1600mhz/Cas7 but can't even pass memtest86 at 1066 speeds with Cas9 timings. Edit: The Bsod is error code 0x0000001a.
Any suggestions would be much appreciated! Thanks in advance.
-Chance Coats
Test 0, pass.
Test 1, fail.
Test 2, pass.
Test 3, pass.
Test 4, pass.
Test 5, fail.
Test 6, pass.
Test 7, fail.
Test 8, pass.
Test 9, pass.
-Chance Coats
