- Jan 10, 2012
don't worry about that just yet, get us the screen shots of hardware monitor first please.
Edit: I'm reading some other forum posts right now and they say that the PHIIs max at 62 C? How is this possible.
They become unstable around that temp. Ive read anywhere from 55C to 65C as max stable temps. Dolks Guide here on the forums has been my Phenom II Bible and states 55C and I shoot for as far below that as I can manage with my 955BE.
Your first stop should be to take look through Dolks Guide to see what you can learn there, and after that I imagine you will head into the BIOS to apply some of that knowledge. When you get stuck bring back some screenshots and I am sure the folks around here will be able to see a few more Mhz in there, or help you stabilize the clocks you are at. Good luck
Judging by thos pics that's not a new cooler and should be doing better than it is. So either it's starting to fail or your mount/TIM is bad
What constitutes stability though? If I run prime95 for 2 hours like trents was originally describing and nothing crashes how is it unstable?
[/QUOTE ]
There is no 1 size fits all definition for stability, so that us tough to answer. As for your chip passing prime95 for 2 hours, that is "gkod enough" stable depending on my level of patience for the day. While I have never gone higher than 56C on any of my 3 Phenom II X4's it is my understanding that over 55/60C they become... "flakey" is the word that was used. What that means is that your chip will start acting up and throwing errors and perhaps BSODs over time. Kind of like running your car engine too fast without shifting gears : just not good for it.
[QUOTE ] Here you're talking about overclocking, but we haven't even established what to do about the high temperatures?
Wow... It got hotter with less voltage? Its about time I bow out and let the wiser folks help you then because I don't know what to make of that. I just pulled Johan's post back up to the front of the line here because you might have am issue with your thermal paste or something and I didnt notice if you already crossed that question off the list.Judging by thos pics that's not a new cooler and should be doing better than it is. So either it's starting to fail or your mount/TIM is bad
how about we start all over here?
shut the rig down, retim and reinstall the cooler please.
fire up prime 95 with cpu-z open with three tabs showing, cpu, memory, and spd and post a screen shot after 20 mins, while it's still under load please.
