- Feb 17, 2010
- Manassas, VA
The case won't fit a 360mm without modding, and I don't think he wants to mod.
The UT60 rad I linked you to earlier should be more than enough for your cpu AND gpu.
http://www.aquatuning.us/product_in...ull-Copper-360mm---White-Special-Edition.html
You really do not have to go overkill with numerous rads.
Oh, with a radbox, gotcha.
If it's possible to do it alone with this rad. would it be possible for a 240 + a 120 that can fit in the case as well? both are 360.
That's not really the way water cooling works, once again, water cooling really takes over a month of research before really making any assumptions. (this coming from someone who did all the research and finally decided against it.)
Kasey, you have 127 posts in this thread. I have seen builds like your's with 25 posts.
It's getting really old really fast. Your magic rig you dreamed of is just ....
You didn't have a clue before you started since you didn't know squat and jumped in like a monkey with no limbs chasing a banana in a fast running stream. The monkey dies.
It's your choice. Do you NEED it now? You got the cash? You must build it now or are you just planning etc?
Step back. Start over. Read read read. And stop this crazy thread. Your by far not the frst to want to build a spaceship to Mars and all you know is "It's a box, it has stuff, make it go to Mars, help me I have no idea what I'm doing".
This has to stop.
I seen many 14-17 year old folks here do the same thing. Are you one of them?
...that's not how you do it. You have a LOT more research to do about water cooling. You gotta calculate the heat load for all of your parts, set a goal dT, and find tests on your radiators that show the heatload dissipated vs fan speed.
http://www.overclockers.com/guide-deltat-water-cooling/
This has to stop.
