OK to start off heres my setup:
Thermaltake XaserIII (w/o purple side panel fan apparatus)
Titan Vanessa CPU cooler (w/ 90mm fan @ 46CFM)
And the rest is current in my sig...
So I turned the computer on leaving the side panel on so that the case was completely closed up...after 10 minutes of idle my coretemps were both 51 and not moving up or down.
So then I removed the side panel of my case...2 minutes pass and my coretemps were both 47...after 10 minutes my coretemps went all the way down to 43-44 and not moving.
I figure the airflow in my case must suck if leaving the side panel off cools down my CPU more than 7 degrees C.
Heres how my fans are set up now:
RED ARROWS: 80mm Fans
BLUE ARROW: 92mm CPU Fan
GREEN ARROW: 80mm PSU Fan
Any suggestions? Am I doing something fatally wrong here?
