- Jun 5, 2011
[worklog 99% completed] Rig AKA "The Hamster Network".. The constant..
Rig AKA "The Hamster Network".. The Constant run towards evolution !!
The Evolution from "Reference Cooled", to H70 | Omni ALC setup, to Full Custom loop..
Omni ALC and Corsair H70 assembled
Omni ALC and Corsair H70 assembly process
CM HAF X Side Panel Mod + Water Cooling gear going thru the test leak...
Stock Temperatures...
Showing off some of the H20 gear prior to assembly and first phase of installation.
Temperature test run #1
Botched up my Apogee XT.. Parallel fittings finally arrived..
Red panel mod with temp sensors.. redid the TIM, temperature test run #2
Vertex 3, More Gelid Wing 12's, POE switch and IP Cam arrived..
Some pre sleeved cables arrived, Koolance 370, EK Dual Top, misc goodies and Case Labs M8 + Pedestal..
Case Labs M8 + Pedestal unboxing and a weird Thermochill TA 120.3 experience..
CM HAF X gutted and parts every where... oh my...
Showing off the Case Labs M8 in all it's glory..
Thermochill TA 120.3 cleaned.. Koolance, Mayhem's, and Bitspower order delivered and unboxed..
Case Labs M8 slightly modded for fill ports and port holes..Pedestal Assembled..
80% Completed...
Demciflex Filters ordered..
Aqua Computer package arrived and unboxing time.. Demcifilters arrived also..
Aquaero 5 XT, Power Adjust 2 x6, flow and inline temp sensors.
Temperature test run #3, Aquasuite 2012 overview..
AquagraFX 580 installed, 99% Completed !!!
Hamster Evolution Rev 2
Surround is not enough !!
Birth of the Hamster Network..
Reference Build
Corsair H70, Coolit Omni ALC ("an H70 for GTX580"'s)
Custom Loop HAF X
Custom Dual Loop w/ Caselabs M10+Pedestal
Custom Dual Loop w/ Caselabs M10+Pedestal v2
Custom Dual Loop w/ Caselabs M10+Pedestal v3
Hamster Wheel v1.0 !!
Hamster Wheel v1.1 !!
WARNING: NOT 56K Friendly....
Current Status : 99% Completed..
Components
Intel Core i5 2500k | Gigabyte P67A UD7 B3
Corsair Dominator GT 4x2GB DDR3 @2133 C9 XMP | Corsair Airflow Pro
Gigabyte 580GTX | Gigabyte 580GTX | MSI 580GTX
Silverstone 1200W Strider Gold | Seasonic 560W 80+ Gold | Corsair AX1200 | Corsair AX750
1x ADATA S599 SSD (100GB) | 2x Velociraptors 74GB (RAID0) | OCZ Vertex 3 240GB | 2x WD Blacks 2TB (RAID1)
Pioneer CD/DVDRW | Imation External USB DVD/RW
LG Flattron E2241 x3 | Ergotron LX Triplemount Displays
Logitech G15 v2 | Logitech G19 | Logitech G500 | Saitek Cyborg Command Unit
Harmon Kardon Soundstick II
Creative Labs G500 5.1 Surround | Creative Labs DDTS-100 Decoder | JBL 610 Headphones | Nakamichi Sound Cube
Cooler Master Haf X | Caselabs M10 + Pedestal
Windows 7 Ultimate x64
Liquid Components
Corsair H70 | Swiftech Apogee XT - Modded | Koolance 370
Lamptron FC8 (x2) | Zalman ZM-MFC3 (x2) | Aqua Computer Aquaero 5 XT + Power Amp 2 (x6)
Coolit Omni ALC GPU Kit x2 | Bitspower Black Freezer VG-NGTX580 + Back Plate x3 | Aqua Computer AquagraFX 580 x3
EK Dual Top Black Acetal + Bitspower Dual D5 Mod Top + Mod Kit (BP-6552D5AC-MBK) | Dual Koolance RP-452x2 Dual Reservoir
Bitspower 525 black Reservoir | Bitspower Z-Multi 80 x2
Swiftech D5/655 (x4)
Black Ice SR1 360 |Black Ice SR1 240 | Black Ice SR1 120 | Thermochill TA120.3 (x2) | Swiftech MCR320-QP
Aqua Computer Stuff
Plug for relay connector, 3 contacts (for aquaero 5)
Plug for relay or power output connector, 2 contacts (for aquaero)
Filter with stainless steel mesh, ball valves and mounting plate, G1/4
aquaero 5 XT USB fan controller, graphic LCD, touch control, IR remote control
Einbaublende für poweradjust 2 USB, Aluminium schwarz eloxiert
poweradjust 2 USB, ultra version
Flow sensor "high flow" G1/4 for aquaero, aquastream XT ultra and poweradjust
Frontplate for aquaero 5 XT aluminum black
Temperature sensor inline G1/4 for aquaero, aquastream XT and aquaduct
waterblock for aquaero 5, G1/4
RGB illumination module for aquaero 5
aquagraFX for GTX 580 and GTX 570 (GF110) G1/4
twinConnect kit for GTX 590/580/570/480/470/460 and HD 6990/6970/6870/6850/6790, width 5 slots
Connection cable for flow sensor (for aquaero/aquastream XT Ultra/poweradjust)
Shoggy Sandwich
Miscellaneous
Koolance VL4N-F13-19S Male Quick Disconnect Nozzle
Koolance VL4N-F13-19S Female Quick Disconnect Nozzle
Koolance VL3N MG
Koolance VL3N-F13-19S
Tygon 3603 1/2 ID 3/4 OD 1/8 Wall | Primochill Pro LRT Red and Blue
Blue UV cable coils
Bitspower Mat Black Straight Fittings
Bitspower 90° Mat Black Rotary
Bitspower 45° Mat Black Rotary
Bitspower Silver Shining Compression Fittings
Bitspower Silver Shining T Blocks (for parallel GPU)
Bitspower Silver Shining Multi Link Adaptors (for SLI)
Bitspower Acrylic Tube (for SLI)
Bitspower Silver Shining 90° Rotary
Bitspower Silver Shining 45° Rotary
Bitspower Silver Shining Straight Fittings
Bitspower Silver Shining Stop Fittings
Bitspower Silver Shining D-Plug
Generic Stainless Clamps
other Bitspower Stuff
MCP655 x2 + Dual D5 MOD TOP (Acrylic Version) + D5/MCP655 MOD KIT x2 Model Name: BP-6552D5AC-MBK
O-Ring Set II Model Name: BP-WTP-O502-BK
UV Blue O Ring – Bitspower Model Name: BP-WTP-O10-UVBL
G1/4" True Silver 1/2" Fitting Model Name: BP-SLWP-C01
G1/4" Carbon Black CaseTop Water-Fill SET Model Name: BP-CBWP-C04
G1/4" Carbon Black Low-Profile Stop Fitting Model Name: BP-CBWP-C09
G1/4" Matt Black IG1/4" Extender-15MM Model Name: BP-MBWP-C60
G1/4" Matt Black IG1/4" Extender-20MM Model Name: BP-MBWP-C61
G1/4" Matt Black IG1/4" Extender-25MM Model Name: BP-MBWP-C62
G1/4" Matt Black IG1/4" Extender-30MM Model Name: BP-MBWP-C63
G1/4" Matt Black IG1/4" Extender-40MM Model Name: BP-MBWP-C64
G1/4" Matt Black IG1/4" Extender-50MM Model Name: BP-MBWP-C65
G1/4" Matt Black Temperature Sensor Stop Fitting Model Name: BP-MBWP-CT
Matt Black Sealing Plug For ID 1/2" Tube Model Name: BP-MBWP-C31
G1/4" Matt Black Rotary 45-Degree IG1/4" Extender Model Name: BP-MB45R
G1/4" Matt Black Rotary 90-Degree IG1/4" Extender Model Name: BP-MB90R
120MM CUSTOM DESIGN Fan Grill-Honey Combo Model Name: BP-120CFG3-BK
Fan Silencers, cable extenders, sleevings, Thermometers, Probes (cough), etc, etc...
Other Miscellaneous
LG Flattron E2251 x1 | Dell Precision 390
Custom Server i5-2500K | 16GB Corsair Vengeance | Corsair AX750 | Corsair H70 | Crucial M4 240GB | WD Black 2TB x4 Raid 5 | LSI Megaraid 9265 | Icy Dock 4 in 3 SATA Backplane | Xigmatek Asgard Pro
Synology DS211J | 2x WD 2TB Caviar Green Raid 0
APC Smart UPS 1500 | APC Back UPS 500
300mbit Fiber
*Gigabit VPN Firewall* (model and make not mentioned for security reasons)
*Gigabit 16 Port switch*
Planet ICA-HM220W IP Cam - set to detect motion record
80% Completed...
Reference Build
Custom Loop HAF X
Components
Liquid Components
Black Ice SR1 360 |
Aqua Computer Stuff
Shoggy Sandwich
Miscellaneous
Koolance VL3N MG
Other Miscellaneous
300mbit Fiber
