Hi!
I'm trying to figure out what happened with my PC. I have Asus P8H77-V motherboard with Intel Core i5-3570 CPU. Recently I have bvought a new SSD which I connected as the fifth disk to my PC. After testing I have decided to disconnect it(turnig off PC before). When I turned my PC on again I couldn't get a video signal. PS is starting and going offline and strarting again... After tests I figuired out problem is in RAM slots. When I have installed memory in two slots system loaded. When I have installed the memory in the third slot system still could load but I had strangely high voltage in bios(ok, may be not so strange - 1,6 but I set it up as 1,5). Four slots together didn't work. Also I could get only 8GB RAM even if I have installed 3x4GB. Later I have checked 2x8GB and it's working as well) Also I have tried to change memory multipliers, nothig special again, some simple change. After this my current slots got broken but I could use another slots. Now I have two working slots 2th and 3th with 8GB RAM. I thought problem is only in motherboard and I need to replace it. But before I tested some old asus motherboard with 775 socked just to be right and It seems memory slots got burned too. But here is a little another situation: sometimes all slots are working, sometimes are not and also I had 2x256MB and 1x1GB in this motherboard. Now I can start it with 3x256 but if I add 1GB it's doesn't work. I mean It's starting but bios isn't loading as it's with my Asus P8H77-V.
Any ideas? Broken PS? I checked voltage with multimeter and it seems everything is ok. I have CFT-650-14CS.
