I wanted to see here if anyone could help me out with a little quandry I'm having.
I am currently overclocking a P4 2.4ghz 800FSB Chip, on an Asus P4P800 Del.
with 1.5 gigs ram. My OC is 2.8, with ram @ 320mhz, with lowest vcore voltage allowed.
I have a zalman hsf and plenty of airflow. My chip rarely reaches above 35c full load, and sits at 20c idle.
I've been wondering if I could up the ante just a little more and push my chip to 3ghz. The only problem is that everytime I try, everything seems fine except for when I run a torture test.
My current oc has no faults or errors after being run for a full day.. yet when I run the test after overclocking to 3ghz, it faults on the first test!
I've tried lowering my ram speed, and upping my vcore voltage, but all to no avail.
Does anyone have any advice on what I could do to try and make it pass the test? Should I OC my system anyway even though its not as stable, so says "prime"??
