- Jan 17, 2003
- Centennial, Colorado
Well to make a long story short I recently overhauled my work PC because it was a tired old XP 1800. anyways now its much nicer but the case I used for it was this
(Image copyrighted to Xion corporation, linked to show the lights)
Just a case that I got on sale but whats cool is the lighting. Now every time I look at it I think Xbox. And for quite a while now I've wanted to do a mini-itx project so! the ideas start coming and I think. Lets make an 'xbox' and turn it into a ROM gaming machine (legally of course, I do own all games I have roms for )
Anyways what I hope to do here is keep an xbox shell as unmodded as possible (so it still looks like an xbox when Im done) but throw in the Via Epia M 10000 a slimline DVD player (so I can watch movies on it too) a nice sized 3.5" HDD. Mod the front connectors so I can use two xbox controllers in the emulators and mod two other connectors for regular USB. And then possibly a wireless keyboard/mouse, wifi, maybe a card reader. And be able to run it onto a regular TV OR monitor if I choose and get it onto my home network (eliminating the need for large HDD). Also while trying to keep this on a low budget as too much money has been spent recently.
The specs for this machine are as follows:
160W Flex ATx PSU
a 512MB stick from this package
120gig Seagate IDE drive)
HP brand Slimline 8x LG DVD player (just dvd and CD, not burner)
Windows XP Pro (of course )
Thats all for the system, extra components includes xbox replacement game-port assembly, onboard usb hook-up, a CCFL or two, some el-wire. Couple fans and extra heatsinks. Space is getting tight so still need to work out the cooling thing. And still looking for a suitable keyboard/mouse until then I'm just going to be using whatever I have laying around.
My only current issue is finding a small PSU to use but I dont need/want to spend the money on the small ones designed for mini-itx boards because the Xbox is a very spacious box. Just need to find another micro-atx supply and I should be good. (edit* found a PSU that should do the job nicely, and its very small (blade server applications) http://shop.store.yahoo.com/directron/hec160srat.html yay! Anyways, I dont have the master 3d skills that Captainslug has so here is a rough mspaint mock-up of what I intend to do/try here
Depending on clearence the mobo and psu will likely be swapped places for modding and existing holes, etc.
Everything should indeed fit and an empty xbox case is on its way to my house so I can get some more exact measurements. (plus I'm a visual learner ) Until then ya'll can drool in anticipation or something, toodles
*edit* oh ya, I couldnt find measurements of the average slimline cd drive so if anyone would mind sharing those it would be much appreciated. ***I found measurements, so n/m***
160W Flex ATx PSU
