- Aug 15, 2002
- Stanwood, WA
I'm running the system in my sig, which is an amazing system still really. It runs everything like a pro. Basically a bang-for-the-buck system. It was supposed to be the best easy overclocker and such as well, although I never had any luck AT ALL overclocking it, I don't know why. I made it a point to buy FAR too much power, because I think power is the most important part. And while my friend's computers are burning out parts, under mild use, my computer is still running strong after several years, and tons of abuse. That being said
I'm looking to build a bang-for-the-buck system. (I was going to build a doom machine, and charge it all on credit, because it feels like I'm not spending money at all....but then I decided it was unwise ) I think I'm going 32bit, unless someone has a good reason to go 64. I don't see any reason that I would need dual video cards. Want 2-4 gigs of ram. Single processor (unless someone has a good reason to do otherwise). Capacity to overclock would be a bonus. Mostly will be a gaming rig, but I do like to multitask. Like, I'll be playing a game, and defragging a hard drive (not the drive the game is on) at the same time, and maybe doing web design at the same time. I'm running a RAID0 array now, and despite the nothing but bad I've heard about RAID0, I've never had any problems with it, and I do notice a significant speed increase on a few things, which I'm sure is bottlenecked by other pieces of hardware (and hopefully won't be so much with the new comp.) I've ALWAYS used AMD, ABIT, and ATI, but am no longer partial to anything. I do intend on running Vista, only because I need to be proficient with it so I can service it.
So I need some advice on what to get, and to make sure that everything is going to fit together properly.
I'll update this post as I decide on parts.
Keep in mind I'm prepared to change out any at all parts on my list here, at any given moment, if someone gives me a good reason to do so.
Also I PREFER buying things from newegg, but if another site has the same part for significantly lower, I'll buy from there.
Thanks in advance.
WHAT I HAVE PURCHASED:
Intel Core 2 Quad Core Q6600 2.4Ghz 8M 1066 CPU SLACR (G0 stepping) - $175 (ebay)
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - $140 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16813131299
=Crucial Ballistix Tracer 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) $154 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16820148070
COOLER MASTER Centurion Case - $50 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16811119068
PC Power & Cooling S75QB 750W PSU - $145 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16817703009
Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case (CPU) Fan - $10 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16835185054
Thermalright Ultra-120 Extreme Heatpipe CPU Cooler - $57 (Petra's Tech Shop)
http://www.petrastechshop.com/thulhecpucos.html
SVC.com Premium Heatsink Lapping Kit - $12 (SVC)
DVD BURN LG|GH22LS30 22X LS SATA - $26 - Newegg
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16827136153
Windows Vista Ultimate 64bt - $75 (Through a Microsoft friend)
Acer AL2216Wbd Black 22" 5ms Widescreen LCD - $195 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16824009094
ASUS EAH4850/HTDI/512M Radeon HD 4850 - $180 (Newegg)
http://www.newegg.com/Product/Produ...A-Approvel-_-Content-_-text-_-N82E16814121253
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive OEM - $60 (Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound - $7 (Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835202006
Rough total for all taking into account mail-in-rebates and shipping costs -
$1100
Thanks everyone for their advise. I'll post again when I get it all put together and start working on OCing it and such.
Thanks in advance.
$1100
