Systems that are not completely stable have a way of becoming less stable over time. What you get away with now may not be workable in a month or two.
What is your room temperature?
Your room temps seem not to be the problem, then. Let's look at a couple of other things:
1. Problems with cooler seating or thermal paste (TIM) application. I suspect we we ought to redo this but let's go to #2 first.
2. Potential poor case ventilation. The HAF 922 is a great case but tell me how many, how big, where placed and the air flow direction of each fan. Let's start here because it's easy. Air flow in a case should be: Front low to rear/top high. You should have a fan or fans in the front panel that are intake (moving air into the case from the outside) and one or more fans in the top and rear panels that are exhausting air out the top and back of the case. Is this the way your's is?
Oh and another thing, I believe I might have used too much TIM when I applied my hyper 212+. I was nervous about the grooves caused by the direct contact heat pipes so I got a little over zealous with the TIM. One small dot on the middle of the CPU and a tiny dot near each of the 4 corners of my heatsink
Because of the grooves, the paste often doesn't spread well on those exposed heat pipe coolers. But the worst thing you can do is to put too much paste on. In this case, "if a little is good, a lot more should be that much better" doesn't apply. Thermal pastes is less than 100% efficient in heat transfer so the more you lay down the more insulation you get.
Use the "two line" method instead of the "blob" method to apply the paste. I'll explain.
First, take some paper coffee filters and clean the old paste from the heat sink base and the CPU face. Start with dry ones to remove most of it and then finish with one moistened with isopropyl alcohol. Why paper coffee filters? They are cheap and they are shiny hard. The hard, smooth texture doesn't leave behind insulating fibers as do kleenex, paper towels and soft cloth.
Then turn the cooler bottoms up. Lay down two parallel thin (as thin as you can get them) lines of pastes perpendicular to the heatpipes, dividing the area approximately into three equal parts. This way the grooves don't get in the way of the spreading. Then lower the cooler carefully onto the CPU, trying to center it as well as possible to avoid smearing and displacing the paste. Clamper her down! That's it.
I have TIM remover and coffee filters so that's covered. Should my 2 lines be made on the silver part or on 2 of the pipes? No, you misunderstood. The two lines of paste should cross over the pipes. That's what perpendicular means. You, know, at right angles to the pipes. I will do all this tomorrow because I'm to tired to do that now I feel like 2 lines is about the same amount that I used the first time just in a different position lol
Read his sig skyline. He's not using the stock HSF.
yes sorry just read that my mistake. lol but why his temps so high then on a 212+ are the x6 that m uch hotter then x4s? ans sorry to post in another person thread how do i add signature
