what are the manufacturer recommended timings? If you post up all of your CPU-z tabs, that would also be very helpful, including the ram / spd/ cpu tabs
You timings look good if it's stable, if you are not benching it is highly unlikely that you will see a difference running the ram higher then you already are. With 4 sticks of ram you will find it more difficult to run high overclocks because of the increased stress on the IMC. In day in an day out tasks especially gaming you really don't need to run that cpu higher then 4.3-4.5. As manu stated you are much better off ocing the gpu's.
So there you are done. No manual setting in bios is going to run that DDR1866 ram at DDR2400 and likely not even DDR2000. That easy overclock crap is generally for the birds and I don't chirp any.
RGone...
Bro there is a great difference between not likely and won't. If you did; good since those are things you have to try at your end. Not something we need sign off on. Luck bro.
RGone...
Hate to disappoint ya but I'm a gamer just not the online multiplayer stuff. In the game section there's a post for steam names. You should check it out.
