- Oct 7, 2004
Greetings everyone:
I would like to startoff by saying I have a tramendous respect for those of you who WC. This stuff is NOOOOOT easy!
But heres whats happend so far:
I spent lastnight installing my WCing cooling kit and things were shakey. Lets just say there was some blood, cuts, and extremeexhaustion. But I still got everything up and running.
I started to discover a few problems when I heard some weird noise coming from my swiftech storm water block. I think it was bubbles but was not sure.
Also, I was not sure if U properly installed my reservoir(the new swiftech micro). The directions are kind of confusing. The routing diagrams say: CPU>>>>res in and Res out>>>pump in. only problem is, on the directons for the res it says:
So on the route sheet it says CPU to res IN, but on the res directions it says IN from pump. so you can see my confusion. I would like to know which one to follow.
SECOND ISSUE
My second issue is the swiftech storm. The directions did not specify which barb is in and which is out. Also, it does not specify which orientation the block should be installed in.
My setup looks like this :
I would like to know if this orientation is ok.
Also, I would like to know if those weird little noises, that sounded every couple seconds or so in the water block, are normal.
Lastly, is there an easier way to remove the tubing from the barb? its so difficult to getoff sometimes i think I'm going to break it.
ANyways, thanks for any help guys. I am so tired, my head hurts, and I'm bleeding. I also think i injested some of that green water
BUT I WONT GIVEUP......unless it kills me
SECOND ISSUE
