You should be able to drop down that vcore by at least 0.2-0.4v more, I would suggest dropping down from 1.37v in 0.05v or 0.1v increments. With that adjustment you could easily shave a few 'c of your temps.
Yeah, the printer is an Epson 980, and it was just a bit overbuilt/overpriced to be real popular, but it IS a *quick* and dandy inket.
That earlier number, minus the extra period, was the AM template version, not the ASUS final BIOS version - mine was indeed old, not even on the page of possible downloads anymore, so I decided to upgrade the BIOS after all.
I had it up to 43 X 103 with the old BIOS, but the temps were getting over 70 when I was folding. BIOS said the VCore was 1.36V, which doesn't seem bad, but with the 1704 BIOS, I'm hoping to ease that down a bit - or lower the LLC or PLL - either one will lower the temps, and hopefully one setting or the other, will also keep the system nice and stable.
The new V7 folding client (still beta), is a DREAM to set up and use. Finally, FAH got a professional to write the folding client program! This is the first time I've run the new client.
I'll let you know how it goes - either 44 or 45 would be good if the temps are 70 or less while folding.
Down clocking is due to over heating. Are they oc'd?
I have the 275 drivers no prob. Sometimes the cards underclock with no loads (2D mode). Don't know why it stays there. You using msi afterburner?
Anyway, it downclocks when the VRMs get hot which may not be reflected by gpu temps.
True on the power saving, but then we go and OC it all to hell lol. Idles lower though if you have speedstep enabled and phase mode set to standard or optimized.
Edit: Still an OC'd 2600k will use less power than a 9xx i7 and will be faster Had I already had a 9xx i7 I'd prolly have to keep it. I almost bought one as they were selling for $179 at my local store. Glad I spent the extra $100.
Hmm, to pay back $100 in power, that's 1000 KWh. 1000 KWh at 40 watts (.04 Kw) is 25,000 hours, or about 3 years, For the entire chip ($279), you jump to 8 years or so. Of course, that assumes that I don't continue to use the 920--obviously there would be no power savings at all if I did
According to JEA's (in FL) rate site:
http://www.jea.com/services/electric/rates_quarterly.asp
Nobody pays .04 per Kw for residential electric service from a utility company that I can find, anywhere in the USA. Lowest is .074, and I'm paying .081 per Kwh JEA's site claims, but that isn't accurate, anymore.
Think UP!
Michael Bloomberg gave 50 million dollars to the Sierra Club to fight against the building or renewal, of any coal fired electric generator plants. We get about 40% of our electricity from coal fired plants, in the US.
Shorter supply, more demand (and now electric vehicles!). Rates are only going up, imo.
My rates vary between .15 and .30 per Kwh, as you can see in the footnote to the table of tier info, here:
http://www.sdge.com/documents/forms/roombyroom-eng.pdf
(part way down the page, on the right hand side, right below the unbelievable picture of two guys, doing laundry -- right!)
So your figures are way low (four times too low for me), putting your time for payback, well off the mark.
