- Dec 16, 2013
- South Texas
Hello all I'm looking for a little input here I put together this new system for my wife and I'm looking to get as much performance out of it as I can, so I thought I'd share with you where I'm at now and see if you guys think I could or should try to go a little further. system specs are.
Asus Sabortooth 990fx r2.0 (bios ver 1903 i think)
AMD FX-8320 (currently @ 4.4ghz w\22.0 multiplier)
Corsair Vengeance pro ddr3 @ 1866 w\9-9-9-24-1t timmings
2-Asus 7850 2gig cards (currently running @ 1000mhz core and 5200 mem)
Corsair HX-750 p\s
Corsair C70 case
Corsair H100i liquid cpu cooler (w\ SP120 quit edition fans in a pull config. exhausting through the top of the case)
2-Corsair 240gig GS ssd's in raid 0
Corsair fans through out case as follows
AF-120QE in the rear for exhaust.
2-SP120QE's in the very front (MB controlled)
2-SP120QE's right behind the hard drive cages(connected to a fan controller)
2-SP140QE's mounted to the side blowing on the vid cards and mother board.
the CPU is Idling @26c and peeking @47c with stock voltage 1.38 I think.
Graphics card are Idling @38c and peeking at 71c (this was with out the side cover on I'll check tonight and see what they do with the cover on and the fans blowing on them.)
Scores 7.8 on WEI Lol for what that's worth.
3Dmark11 score 10984 so far thats really the only bench marks I've thrown at it. I did play Bioshock Infinite for about 4 hours yesterday with no problems.
one odd thing I've noticed but I could be doing something wrong is when I try to increase CPU vcore in the bios the system immediately hangs and will not post. (i.e. that's why its still at stock voltage) but it seems to be fine at 4.4 even with the stock voltage.
Corsair HX-750 p\s
Corsair C70 case
