Just wanted to check-in and say everything is going great with my oc! No problems at all.
Though I now realize that my hdd is dying (it's at least 7 years old and is in dire need of upgrading). This has me worried about my oc, but I believe all of the bios settings are saved on the mobo itself, right? Also, if I replace my hdd will I have an issue installing the mobo drivers from the cd provided even though I've flashed to the latest version?
Thanks in advance for the assistance!
Yes, I am on a cell atm.
Thanks for the info. Would you suggest installing windows first then the mobo + other drivers?
Should I go ahead and update the driver or just leave it be if it's working?
Thanks again for all the advice, I'm always a bit uneasy when I have to reinstall mobo drivers, but everything went so smoothly.
Did you replace that hard drive yet? I assume so because it sounds like you reinstalled stuff but you never really come out and say you replaced it.
propama said:I guess I'll just keep letting it run? Hopefully more vcore was the tweak it needed!
