Greece bad economy save money:
http://www.skroutz.gr/s/2352867/Asus-Crosshair-V-Formula-Z.html?keyphrase=crosshair+z
http://www.skroutz.gr/s/2524848/AMD-FX-8350-Box.html
http://www.skroutz.gr/s/4383806/Gigabyte-Radeon-R9-290X-4GB-OC-GV-R929XOC-4GD.html
http://www.skroutz.gr/s/3731583/Samsung-840-Series-Evo-120GB.html
800 euro, thats 100 cheaper then your original and better video then a 970
You can game better and once you get your custom loop you will get a nice OC with that mobo and CPU
Hey Zakarro, thanks for your answer.
100€ for the perfomance margin between the two builds is a price I can live with. I had an AMD build, I really like AMD, but that 8350 won't match the 4690k at gaming, OC'd or not.Now since 290x and 970 cost the same, the 970 is slightly faster so I will stick with the 970 since I'm doing a lot of Photoshoping as well. Besides I already ordered the mobo and the case, I just want an opinion on people that worked with the Seidon 120v or Antec 650 or both!
I would take a good air cooler over any single radiator AIO.
The Seidon will be better, but I would take a good air cooler over any single radiator AIO.
The 212 EVO is just a good budget air cooler.
You'll get better performance for the money with something like the NH-D14 than any single radiator AIO
Yeah for low profile thats what I was gonna say the EVO.
212 Evo is in no way low profile.
Ihad ignored you but I made this exception, the definition of low profile means low space meaning not tall like my ACX for example and the evo is short compared to that.
The EVO is a tall tower cooler................
http://www.newegg.com/Product/Product.aspx?Item=9SIA4DA1WK1545
Not nearly as tall as my ACX or Dark night or a noctua
I give up lolStill not low profile.
Something like the NH-C14 would be considered low profile.
I give up lol
You were listing off tower (aka u-style) coolers, which aren't ever low profile.
All the best low profile are c-style coolers.
You're fine w 8GB for gaming.
I may have missed it on the first page, but did you look at the Corsair Air 240? Supports matx and mitx and has rubber-grommetted holes for cable management behind the mobo tray (something both the hadron - which I otherwise love - and prodigy - which I don't like - lack).
