- Sep 7, 2013
The plan is to have new case finished before the snow hits.
I already have some tubing and 3 1/2" ball valves to act as bypass valves.
All i do is switch off the bypass valve and open the other 2 and voila! the loop will flow to the rad outside my window, bypassing the one in my case which would only add heat since it's colder outside than in my case.
Anyway, all I need to know here is what rad I should get for hanging out my window?
A small 120? 240??
I currently have a Blackice GTX 280 (?) (it's either 240 or 280... I threw out the box but Bassnut will know, I bought it off him) and from what I can measure, it's not really enough. I have about a 19C delta from ambient to load temps, so I'm thinking the same size rad will do best out my window.
I'll try and measure my fans tonight to confirm the size of the rad.
Thanks guys
A small 120? 240??
Thanks guys
